blueflash
Predicted top speed on radar now with clutch done ???
Any Idea on what to expect to see on the radar gun now on ice with my set up like this now.
52/44 helix 8dn-20 weights with 4.5g both holes
WWWprimary...Green secondary...
1 inch track with 192 studs.
Stock gears
I just had my powervalves serviced and there good to go also.
Any ideas on what other sleds it should compare too from start to finish?
Stock gears
bufalobob
what distance & what rpm are you running???
bob
bob
blueflash
about 1000ft and I dont know what rpm its running at because I havent had it out to the lake yet because I just did the clutch a couple of days ago and wont be heading out to the lake until Sunday.
bufalobob
run it @ 8500. 95 mph would be good.
bob
bob
blueflash
how fast do figure it would be if it was stock clutch
bufalobob
a stock clutch setup adjusted to run @ 8500 rpm's should run about 95 mph in 1000'.
bob
bob
pro116
Lifetime VIP Member
I ran my 01 srx stock with 192 trail studs in 1000ft glare ice 94mph on radar a feww weeks of tuning it was up to 110.
jamesfiii800
i had my gfs 117 topped out but i dont know whats been done to it we bought it and never took it apart
bufalobob
pro116:
better get that radar gun checked and/or remeasure your distance. 110 on a stock srx700 with a trail track & 192 trail studs in 1000' just isn't going to happen.
bob
bob
pro116
Lifetime VIP Member
Bob sorry I ran 94 with track and trail studs then switched to a 1/2" lug 144 ice pick's plastic backers,slide lubers other little trick's.The radar gun is accurate I ran on numerous different one's.I didn't mean to get you rialed up.
bufalobob
pro116:
that's more believable.
bob
bob
Spin that baby 8200-8300 for draging
YAMMIEGOD3:16
GUESS IAM DOING ALRIGHT ACCORDING TO YOU GUYS TIMES. !! 2000 SRX, 21/40 GEARING, STOCK TRACK, 192 CHISELS, 96.8 IN 660 ON GPS. COOL!!! 3:16 (tony)
blueflash
how long would you need to hit absoloute top speed? 2000ft. Im not sure because its my first year with a srx 700 and I havent be able to ride it that much because the weather here in southern ontario has been horrible. Its like spring up here.
vipertripplexxx
Results will vary
On the gun
2000 srx, stock with clutching, 118 on sheet ice with stock track and pics.
1999 srx 600, same conditions, 113.
Both @ 2000 feet, thats pretty much top speed, with light riders.
If you have an aftermarket track, you may loose some speed from the stocker. yoko is a good speed track.
On the gun
blueflash
So you figure with the setup I have it should be hitting around 115mph on the gun??
BadAzzSRX
blueflash,
I have my clutch parts, but don't have them in yet. No big rush here as we have zero snow. If you get your sled out first, would pm me or post how your setup is working out. I'll do the same.
blueflash
just got back today. Poor ice conditions warm and kindof slushy. Locals say I should hit 10mph more when its good. I still hit 109.3mph
