Predicted top speed on radar now with clutch done ??
blueflash
Paris Ontario Canada
Predicted top speed on radar now with clutch done ???
Any Idea on what to expect to see on the radar gun now on ice with my set up like this now.
52/44 helix 8dn-20 weights with 4.5g both holes
WWWprimary...Green secondary...
1 inch track with 192 studs.
Stock gears
I just had my powervalves serviced and there good to go also.
Any ideas on what other sleds it should compare too from start to finish? :itchy:
about 1000ft and I dont know what rpm its running at because I havent had it out to the lake yet because I just did the clutch a couple of days ago and wont be heading out to the lake until Sunday.
I ran my 01 srx stock with 192 trail studs in 1000ft glare ice 94mph on radar a feww weeks of tuning it was up to 110.
pro116:
better get that radar gun checked and/or remeasure your distance. 110 on a stock srx700 with a trail track & 192 trail studs in 1000' just isn't going to happen.
bob
Bob sorry I ran 94 with track and trail studs then switched to a 1/2" lug 144 ice pick's plastic backers,slide lubers other little trick's.The radar gun is accurate I ran on numerous different one's.I didn't mean to get you rialed up.
GUESS IAM DOING ALRIGHT ACCORDING TO YOU GUYS TIMES. !! 2000 SRX, 21/40 GEARING, STOCK TRACK, 192 CHISELS, 96.8 IN 660 ON GPS. COOL!!! 3:16 (tony)
how long would you need to hit absoloute top speed? 2000ft. Im not sure because its my first year with a srx 700 and I havent be able to ride it that much because the weather here in southern ontario has been horrible. Its like spring up here.
Results will vary
On the gun
2000 srx, stock with clutching, 118 on sheet ice with stock track and pics.
1999 srx 600, same conditions, 113.
Both @ 2000 feet, thats pretty much top speed, with light riders.
If you have an aftermarket track, you may loose some speed from the stocker. yoko is a good speed track.
blueflash,
I have my clutch parts, but don't have them in yet. No big rush here as we have zero snow. If you get your sled out first, would pm me or post how your setup is working out. I'll do the same.
