Need some help with studs.
akrievins
Mississauga
I really would like to stud my stock track with 96 or 120 studs. .750 studs which are recommened are virtually impossible to find. I have come across lots of .875's. So, can I run these in my .540 stock track? Also, do I absolutly need to put tunnel protectors in? It would be easier for me to do that in the summer.
Let me know what you guys run in the Phazers.
Thanks.
you can run the .875" no problem.only way you will get .750" is in t-nut style which arent that good.if you need some .875" let me know.96 would be more then enough.you dont really have to run tunnel protectors unless your jumping.but they are also cheap at $20 a pair.
Thanks richierich!
I'm gonna try to snag some off ebay for cheap. (less money the better)
Incase that falls through, what do you have?
