ThePunisher
- Jan 25, 2005
Having a problem with my sled.
When I start it cold it will idle fine for a few minutes and then it will drop down to idle at under 1000rpm...maybe 500 rpm tops. Sounds like it's stumbling, the only way to keep it going is to turn up the idle adjustment screw.
I'll let it run like that until it's warmed up. When I ride seems like she is still stumbling. However when I shut the machine off for a few minutes and start it back up again it runs like a champ. Although I then have to turn down the idle because it is way too high...
Any ideas?
Any ideas?
FuzzButt
Have you cleaned the jets recently? Mine used to do almost this same thing. I cleaned and adjusted everything and it runs steady again.
