Yama49601
I just wanted to check with you guys about this before I end up getting a track that is gonna cause me major headaches.
Will this fit if I remove the heat exchanger protectors on the front? It looks like it should and I am pretty sure I read it will if I don't use studs. The guy I ordered it from says no way.
Oh, I have tunnel protectors too but I plan on removing those too if I have to?
Thanks.
Thanks.
