SpartaSXr
hey i just bought a set of SLP triples for my sxr 700. it has the head gasket mod done already and i was wondering if this will create any problems? any info will be appreciated. thanks
No sir , no problems at all , just run 91 oct. or higher.
yamaholic22
yup i ran one for over 3,000 miles with cpr's and two layer head gasket. Always ran premium, no problems at all until the headgasket blew at the end of the season. Didn't peel the new one.
yamyrider
I took the middle layer out on my piped SXR700 only put 120miles so far.
just keep an eye out for jetting.
bluehammer
You'll need to upjet.
2001_blue_sxr
- Oct 20, 2005
- New Liskeard, Ontario, Canada
- www.vanducchiracing.com
yamaholic22 said:yup i ran one for over 3,000 miles with cpr's and two layer head gasket. Always ran premium, no problems at all until the headgasket blew at the end of the season. Didn't peel the new one.
same here...that made a mess...i had 2 of 'em let go...all the coolant got pumped back into the little tank...ughh...it did a lil difference tho for the 30 miles i had it done tho...lol...
yamyrider
Hey Pat, how is that SXR running.
2001_blue_sxr
- Oct 20, 2005
yamyrider said:Hey Pat, how is that SXR running.
its good now that i fixed everything...got the cluttching down too finally...now i just gotta go re-test drive it till somethin else breaks on it....
SpartaSXr
runs great! very dependable. it has 8000 miles on it now. slp recommends 147.5 mains. what do you recommend blue hammer?
thanks for all the replies guys.
yamyrider
What do you have for pilots and needles.
With Aaens and one layer peeled from gasket I am running 50 pilots and 147.5 mains. Which has been ok but the weather here has been miled
2001_blue_sxr
- Oct 20, 2005
yamyrider said:What do you have for pilots and needles.
miled isnt the word....+5 right now..thats WARM...bring back winter...lol
SpartaSXr said:runs great! very dependable. it has 8000 miles on it now. slp recommends 147.5 mains. what do you recommend blue hammer?
I am running 147.5's straight across, 45 pilots and the stock needle in the 3rd clip (no washers) with my 700 tripple with SLP quiets. I am running 22cc Peak Head and reed spacers and it is very safe (fat wash marks but no fouling) at 3500 ft. at 5 degrees. I may lean it up a little after another ride or two but I am still hesitant because of the elevation spread that I ride in (occasionally down near sea level).
