phazer95
Hey phazer95, whats with the "Intake cut is more aggressive" What does this mean?, on the Wiseco piston?
The wiseco pistons intake cut is wider and taller than the stock piston and is very similar to the original SX piston cut that was used for Yamaha's formula 56 oval race sled. This is the main mod done on the intake side and changes the intake port timing of the motor. If you are intrested in doing this mod to your stock pistons you can go to the Dynotech Research web site and get the exact specs from the modified phazer pipe shootout #9. This is a pay site so you will have to buy a subscription to get this info.
