Want (need!) to stud my 97sx. Went from stock track w/192 to new 1.25 ripsaw. Love the new track, but it's those un-foreseen icy corners where I miss the pokers. Been told I need to reduce drive cogs to reduce distance to front exchanger???
2001_blue_sxr
- Oct 20, 2005
- New Liskeard, Ontario, Canada
- www.vanducchiracing.com
yeah...you'll need to go to 8tooth drivers, and then that'll mess up the gear ratio, so you'll have to readjust the gears too
so, 8 tooth drivers. Do you know the chain gearing to? Then with the smaller drivers I can run standard front protectors, how about for the tunnel just the standard ones to?
2001_blue_sxr
- Oct 20, 2005
see here for gears...
http://www.totallyamaha.net/forums/showthread.php?t=18857&highlight=gear+calculator
as for protectors, i'm not sure...
