SNOWRULES
can i use 8AB's on my 2000 sx-r700 have them laying around from my srx just wondering if they'll work or if anyone has run them in a sxr700 thanks
yes they can be used not sure of the rivet combo you would need though.
SNOWRULES
ok just wanted to know if anybody used these with any success like if they worked well and shifted nicely and all that
I use them in my 01 sx-r...I like them the best for the 700 sx motor.
SNOWRULES
any suggestion for rivet placement for them in an sxr 700 sled has 22/40 gearing, 14.5 mm rollers,stock springs in both clutches, 1 layer removed from head gasket, reed spacers, bored silencer,1 size down on mains, 1 size down on pilots, needle clip set at 2.5, transfer rods by maxx performance, 144 studs looking for good all around trail performance i weigh 185 pounds if this info helps
start with 2.4 g in both holes
SNOWRULES
k thanks alot i'll try that this weekend
