Concept Carbon
my sled ussually starts first with in 3 pulls when cold the smokes for a minute like crazzy, after i drive for a while and stop for gas it wont start i have to squeeze the throtle when pulling the pull start or it just gos blubblupblaaa lol whats wrong also my head light dims when in idles. its a 97sx700
it starts up no prob as long as a squeeze the throttle
change_up
all of the things you described are normal. Most of the triples need a crack of the throttle to start when warm, otherwise it can sometimes take up to 5 pulls. The dimming is normal too. This is due to the lower stator output than that of a dual bulb style sled such as a 2001 and later model pro-action (may be 2000, can't remember.)
Concept Carbon
cool thanks alot this site rocks
Bakemono
Just to rule out rings, do put a compression tester on your sled and see what kind of compression you have.
If its below 110 psi or if the compression in the cylinders isnt close to being even, you probably need rings.
Typically you should re-ring your engine every 10,000 miles and worn rings would explain why your sled is hard to start when the engine is warm.
On every reed valve equipped sled Ive ever owned you have to crack the throttle open when you pulled on the recoil to make it start, and its normal for them to smoke like crazy when the engine is cold.
yamaha98sx700
Is their any way to upgrade the ststor, or is it not worth the trouble?
yamaha98sx700 said:Is their any way to upgrade the ststor, or is it not worth the trouble?
If you want to eliminate the headlight dimming, install an LED taillight -1157
It's not worth updating the stator unless you are converting to the twin bulb headlight(stator,guage pod,lens.....)
ummm,... the headlight will still dim down on idle ,regardless of the led taillight!crewchief47 said:If you want to eliminate the headlight dimming, install an LED taillight -1157
yammy said:ummm,... the headlight will still dim down on idle ,regardless of the led taillight!
Oh ya! I must have been having one of those moments, Won't dim when you hit the brakes. Thanks for the slap upside the head.
