kysledneck
Looking on ebay ! man several to buy I want the stock 60 / 55w h4 what is the diff in xeon, halogen,etc
Man ..not sure of the diff ,but i put a 100/55 w. xenon bulb in my sx and it lights up the trail!
I use a PIAA Xtreme white Great light output but same power consumption
FuzzButt
I love my dual color 65/55 Xenon from Bluhm industries (I think that is the correct spelling) It works well and there is no dimming.
Yamahammer485
Got a PIAA Super Plasma GT-X 135/125w and she lights up very well, by far the brightest out of anyone iv seen. No dimming either.
Waterfoul
I took the cheap way out... Sylvania Silverstar bulb... and then added an LED tail light and eliminated any dimming when braking. Much brighter than the stocker was... and now I have a spare bulb to boot.
Concept Carbon
the higher watt lights dont overheat the wiring, or damage the stator.
The PIAA bulbs have the power outage of a bigger bulb but still consume the same amount of power from your stator 55-80w which is the same as the stock bulb, So NO you won't burn out the stator.I ve had minr in for two seasons now without a problem.
MN98VMAX
Waterfoul said:I took the cheap way out... Sylvania Silverstar bulb... and then added an LED tail light and eliminated any dimming when braking. Much brighter than the stocker was... and now I have a spare bulb to boot.
I did this as well, and finally got to try it this weekend! The SilverStar didn't do much on low beams, but on High's I could really tell... The LED works great too!
Mike
Concept Carbon
would a 100w-80 zenon be ok, or would it do damage.
I don't know what effect the 100/80W would have on the stator.
Your going to be pulling about 8.3 amps on high and 6.6 amps on low
vs 5.4 and 4.5 amps for the stock bulb.
The wire gauge looks to me to be about 14 awg which will safely handle about 15 amps so as far as wiring (at least at the bulb) it will handle the amps.
Toad
Waterfoul, Thrifty idea...do you have model numbers for that silverstar bulb, Ive got an LED taillight already.
94' V MAX 500
94' V MAX 500
Waterfoul
I took the stock bulb in with me to Autozone... matched up the model number to the Silverstar. Easy as pie.
maxtriple
led lighting
i want to run an led headlamp and tail/brake light. do I put the modulator inline before it splits between the headlight and tail section!? where can I get an H4 LED Headlight Bulb...
I am running an 1997 700 Vmax Sx
A couple of bucks
rockstoyz slells a led hid kit through sledtoyz. i put it in my et at the end of last season and like the results. http://www.totallyamaha.net/forums/threads/96434-rockztoys-LED-hid-review is where i put the video and pictures up.
