gwinnraptor
cleaned my powervalves last night, and had to take the black servo cover off and roll the shaft to get the valves to open up for full dis assemble.
my question is:
do i have to roll that shaft back when i put the PV's back in the motor before i fire it up?????
thanks
my question is:
thanks
I would. It will set itself back there anyway, but the cable routing may get crossed up.
Leave the servo cover off, until you have completed the job. Then you can check it out during and after adjustment. Like mentioned above you only need to turn it back if it helps keep the cables in the right spots.
yamaholic22
as these guys said just roll it enough to tighten up the cables so that they all fall into their correct slot on the servo wheel. Hate to break a cable because it didn't drop down into its groove.
