Help! Mtn Max bogging
yamiemax
Northern Manitoba
I have a problem that I can't figure out. I have a 2000 Mtn Max 600 with a Holtzman tempaflow, I just put on a set of Aaen triple pipes, iwent up 1 size on the pilot and 2 sizes on the mains. Now heres the problem, when in deep snow and turning to the right the sled starts to bogg and wants to quit, yet I could turn to the left all day long and it works great. Any help would be greatly appreciated.
Maybe when you are turning right, your cables are pulling on something they shouldn't be, like the choke or something. Lift the sled off the ground and try it, paying close attention to what's moving under the hood, besides the clutchs. Make sure your choke cables are seated properly. It has to be something real basic like this.
will it run ok if you give it a handful of throttle when your turning to the left? My thoughts would be that the exhaust is just getting restricted more when you are in the snow, happened all the time to me with my stock sled, and now even with pipes. Try an exhaust deflector. I always found that if you gave it enough throttle to clear the snow from the pipes that it would work just fine.
