Yah, you need to slow down & start from the basics like newf said.
The way this post started, it sounded like you had some kind of newly discovered exhaust blockage. Now it just sounds like a simple problem that takes common sense to figger out.
Your plugs have to be in serviceable condition with proper gap. You have to open the airbox to see if there's a mouse nest or other blockage. You have to see the reeds to know whether they are serviceable. You have to check compression to know whether the engine is shot. You have to completely disassemble the carbs to clean the bowl & throat, & pilot & main circuits, & adjust the float bowl height & inspect the float needle and seat, & inspect the main needle & check the clip position, and be sure that pilot passages are not blocked and that tiny spring-washer-o-ring under pilot air screw hasn't been lost. You must be jetted and set up properly. Get expert recommendation for jets, then confirm that you have the proper main and pilot jet sizes, and that the needle clip is in the 2 or 3 position. Start with the air screws 1.5 turns out, tune from there. You can verify fuel pump operation by having a buddy crank the motor while you hold your finger over the fuel hose trying to block it. If fuel squirts past a tight "finger-cap", pump is good. You have to be sure there is spark. Pull plug, put cable on it, hold it 1/16" away from conductive surface of head, crank motor. See if a spark jumps across to the head. Don't do this with gas spilled everywhere. You have to be sure there's not a vac leak at the carbs or water pump shaft or other typical locations. Use starter fluid: get sled running, spray little bursts all around each carb. If it revs up suddenly, that's because it sucked starter fluid in through a vac leak. Do the same test at the water pump shaft seal and other possible leak aveneues. If you find a vac leak, fix it.
Your clutch has to be serviceable. This means good bushings in both clutches, good weights and rollers and pins and spring in primary with no wear dimples in the weight profiles, and good spring and buttons in the rear. Springs must be set in proper holes.
The problem you describe could be caused by bad pilot circuit, bad main circuit, bad float system, wrong float level, vac leak, bad plugs, blown motor, bad fuel pump, bad fuel, water in fuel, bad clutch, blocked air intake, or bad karma.
If it's karma, get really drunk and bark at the moon, then wake up and start over.
Good luck.
