Concept Carbon
Ok i have stock pipe and bender can, will bender tripple pipes be louder then what i got, if so how loud, is it loud all the time or only when you pin it.
Im a trail rider that wants more speed without getting a ticket. Or pissing off poeple.
Feed back please.
Feed back please.
bluehammer
We ran them on our 800. You won't be disappointed with the sound that they make. I don't think they're much louder than any stock set of triples. Sort of a "ding-ding" sound.
Concept Carbon
bluehammer said:We ran them on our 800. You won't be disappointed with the sound that they make. I don't think they're much louder than any stock set of triples. Sort of a "ding-ding" sound.
cool will i notice a sufficent gain, will i be able to keep up with a bone stock srx
redrider24940
I have a set of power inc. triple pipes with silencers. I had the same setup you did and I think that the triple pipes are softer than the can was. It sounds close to a srx with silencers on it. PUT THEM ON YOU WILL LIKE THEM!
bluehammer
The pipes should add enough hp (maybe 20+)that the SRX shouldn't lose you in the trails, even in the long wide ones. But it will pull on you going down the lake when it stretches it's legs. Should be a close race with shorts bursts on hardpack. Gear and clutching changes may be required.
Concept Carbon
i whiegh 240lbs.
springs?
helix?
Concept Carbon
is there a way to install a silencer on them
snowfoxsx
what do you mean? the triple stingers are not good enough, they have a good bark but are a lot quieter then the can which is good. mine sound great!jaysV-MaxSx700canada said:is there a way to install a silencer on them
Concept Carbon
i just want to know how loud they are, im worried about getting a ticked,
"a good bark but are a lot quieter then the can which is good"
so it will be quieter then what i have now(stock single pipe with bender can)
please any info helps.
bluehammer
What, you want someone to send you an audio so you will know for sure? Go buy the pipes like the rest of us have to and then you will really know what they sound like.!!!
SpartaSXr
bender silencer? i had a dynaport with the stock pipe and i dont think it gets any louder than that...
Concept Carbon
bluehammer said:What, you want someone to send you an audio so you will know for sure? Go buy the pipes like the rest of us have to and then you will really know what they sound like.!!!
man who pissed in your corn flakes. All i want to
I thought forums are for people to talk and help other people, i guess some people just use then to vent.
