culvert
have a line on a used 98XTC-P 700. only has 2000kms.
what things should I check out on it before buying. mostly wonder about the things I wont be able to see.
culvert said:have a line on a used 98XTC-P 700. only has 2000kms.
It was the 97 700 sx that had a pto side bearing issue, fuel line relocation, spindle update, bump stops in the w-arms......take a look at the track, the stock tracks back then were the biggest heeps of crap to date.
I had pto bearing go in my 97 700 mm. Yamaha updated it even tho it was way out of warranty.
snowfoxsx
Turk said:I had pto bearing go in my 97 700 mm. Yamaha updated it even tho it was way out of warranty.
how far out of warenty was your 700, i have a 97 700sx with 11000km and it is fine i think, just wondering? by the way do you have any clutch and jetting setups for my sled with bender pipes? i just got a clutch off a 01 mm700 and would like to set it up. the springs are longer in these right?
Gee...a bender piped 700 question. I will take a real wild stab at this. For a good clutching set up run a long style y-g-y primary spring, 89L weights with a 2.4 gram rivet, 51/43 helix with 60 degree wrap. They work best coming out of the hole at 8300 & climb to 8700 max. Run jetting 52.5 pilots, 150 mains raise centre & mag needles. Just taking a guess here tho!!!!! Done this one like a kazillion times!!!!!
LMAO, I would have just told them to go look in the Tech Pages
snowfoxsx
Turk said:Gee...a bender piped 700 question. I will take a real wild stab at this. For a good clutching set up run a long style y-g-y primary spring, 89L weights with a 2.4 gram rivet, 51/43 helix with 60 degree wrap. They work best coming out of the hole at 8300 & climb to 8700 max. Run jetting 52.5 pilots, 150 mains raise centre & mag needles. Just taking a guess here tho!!!!! Done this one like a kazillion times!!!!!
thanks a bunch turk!!
89L weights
I agree that set up works super for a straigt shot 0-whatever, but the 89L's work terrible coming out of a corner.
The tech page should broken down straight liner vs trail set up to help eliminate 89L ' s in every trail riders box of stuff.
snowfoxsx
Re: 89L weights
which weights would you recomend for trail riding with a lake blast once in a while?
thanks
bleueje17 said:I agree that set up works super for a straigt shot 0-whatever, but the 89L's work terrible coming out of a corner.
thanks
I like the 8ab and 8ac for trail
snowfoxsx
MrSled said:I like the 8ab and 8ac for trail![]()
what size rivits and which holes mr. sled? thanks.
derek
what other work do you have done?? Just the pipes??
snowfoxsx
MrSled said:what other work do you have done?? Just the pipes??[/quote
reed spacers, carbon tech reeds, 2 layer head gasket, bender triples and that is about it, any suggestions?
thanks]
8ab w/3.1 in both holes, P-S-P primary, 48/43 helix, white sec spring at 0/2.... this runs good on top and really good on the trail.
snowfoxsx
thanks for the info mr. sled!!
