BadAzzSRX
I have a 121" picked track, stock drivers, Long Travel with Viper Shocks, Maxxperf adj transfer rods and marginal snow wheel kit.
I primarily ride the big trails in Northern Maine. I have it a little on the tight side and think I need to loosen it, but I was wondering how most guys set theres up.
black1000
My 02 cents says that under 20lbs of weight the track should hand down 3/4 to 1" in the middle to the bottom of the slider
I use 22lb's of pull at 1 1/4" at the center of the skid.
BadAzzSRX
With that adjustment, what kind of riding do you guys do?
BadAzzSRX said:With that adjustment, what kind of riding do you guys do?
Semi aggressive trail
dustin
loose is fast... to tight takes away hps... but too loose and youll get racheting, there is a fine line there..... or spend the money on anti rachet divers
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
As loose as you can get the track without slipping on the drivers, the better off you are. Looser will always be faster as long as you are not slipping.
2ooosrx said:Looser will always be faster as long as you are not slipping.
Or slapping off the tunnel
blue missile
better make sure your front cooler guards are there my picks barely miss the cooler. all you need is to get those flapping around.
BadAzzSRX
I have cooler guards on the front cooler and my track is only a 3/4" lug. I loosened it a little. It hangs about a 1/2" from the sliders at midspan, but is snug up on the bend. I have my limiters 3/4" past the nut. With a medium pull on the track (I don't have a scale) I can get it to 1" to 1-1/4" at midspan. It doesn't seem overlly sloppy. I'll have to try it this way and see how it goes. We're leaving wednesday for a big trip, I'll tweak it after I put a few miles on it.
