Yama49601
How do you tighten the belt?
kysledneck
I replaced pump, belt ,seals all of it there! no way to tighten! It just goes over each pully by hand! How much play do you have? I replaced mine just because I figured I better! The belt itself is like an ond enticer fan belt!
kysledneck said:no way to tighten! It just goes over each pully by hand!
WRONG!!!!!.......the pully on the fly wheel splits in half.. there's 3 bolts you
take out and remove a shim(there's 3 in there diff. thickness) put your
belt back on with the pully half and re tighten,,belt then rides higher in the
pully thus is tighter...
kysledneck
CHILL!!!!!!!!!!!!!!!!!!!!!daman said:WRONG!!!!!.......the pully on the fly wheel splits in half.. there's 3 bolts you
Yama49601
Hey thanks. We got it tightened just now. It had a .5mm shim and a 1mm shim in there (someone had already removed one). I tried getting it back together with the 1mm shim removed but it was too tight. I had to put the 1mm back in without the .5 then I was able to get it back together. It's tight now!
Yama49601 said:Hey thanks. We got it tightened just now. It had a .5mm shim and a 1mm shim in there (someone had already removed one). I tried getting it back together with the 1mm shim removed but it was too tight. I had to put the 1mm back in without the .5 then I was able to get it back together. It's tight now!![]()
Obviously don't throw that shim away.
kysledneck said:CHILL!!!!!!!!!!!!!!!!!!!!!
I wasn't yelling!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
