vmax700sx
- Nov 19, 2003
Is it ok to do the Head gasket mod on a 2003 Viper?
No, not recomended
vmax700sx
- Nov 19, 2003
Labor day is soon here. Time to start thinking Sleds again!
Why is the gasket mod not recommended? Are there other mods that need to go along with it?
What problems has it caused?
Thanks.
Thanks.
The cylinders have different compression and the Viper is really on edge with the cooling as is. You will take the risk of burning it down and give yourself quite a headache trying to get it jetted to live.
Mtnviper
If you ride at higher elevations you can. I have ran mine with both layers pulled with it stock and with pipes. However I do ride at 2000'-8000', and always use good premium fuel.
Pulling one layer (.005") will reduce the camber size by .475 cc's
Pulling two layers (.015") will reduce the camber size by 1.42 cc's
It dosn't make a huge difference in horsepower, but throttle response is improved.
nodoo_s
i pulled one layer right after i got the sled and havent had a problem yet (02 viper), i am also jetted down one size. we ride in maine so i would say upto 4000'. i was thinking of removing the second layer but waiting to see if anyone else has done this.
..SNAKEBIT..
hey nodoo_s are you running pipes? or stock
