Friend just bought this sled and it is stock. Went riding this weekend and he used most of his oil in 70 miles. Turk said cable is unseated and it was. Took it for a spin yesterday to see if smoke would clear up and it did. It was 37 degrees out with very little snow. First couple passes I might of hit 70-80 mph, speedo does not work. Tach started out at 8000 and started to drop to about 7800. Did not know where this motor should run but I knew it was off. Performance sucked! Turned a corner in a field and she was spinning 9000 and if felt very good. I now know that it should be 83-8600, not sure why it was still happy at 88-9000 but it was. Made another pass and it spun 88-9000 again. Came out of field and hit trail and nailed it and its only spinning 8000 again. Feels fat when it only runs 8000. That makes sense with what temps were and stock jetting. What I don't understand is the runs that it run 88-9000, same day just a few mins earlier. Thought some one might have a idea.
Thanks Bruce
Thanks Bruce
