Silver Bullet
Last weekend went riding everything was working fine until I had a hose clamp bust and lost a lot of coolant - after this we bled the system a couple of times through the 10mm bleed bolt on top of the cylinder head. After a couple of times of going 1/4 mile between overheat then bleed again my sec clutch froze up. It looked to be engaged all the time and would not open up and spring back into idle position. I think some of the antifreeze must have gotten on the shaft and slides on the clutch and made them sticky when they got hot. What should I use to clean the slides and shaft and what should I use to lube them up? Is there anywhere else that I should lube or check.
Silver Bullet
Silver Bullet
