Just came back from a 4 trip in Quebec. The sled ran great the first day, everytime you hit the throttle it would snap to 9000 and stay there as intended. After some hard long riding the engine cut out completely and only idle for 30-40 secs before the throttle would have any effect. At first I thought I popped the pistons, but the wash and plugs were fine. Power came back and keep riding and then it would start idling funny for 45 seconds after slowing down from a hard pull down the trail. checked the plug spark which was weak ( iridium NGK) put in a new set and had a stronger spark but still a little weak. Problem came back with new set of plugs. Then switched to BR9ES which gave a slightly better spark and no engine problems. however the trails did not permit the same long hard riding as the first couple of days. also takes 1-2 pulls to start when hot versus one previously.
Engine has peak head, boost bottle, cpr pipes, roller secondary, jetted by piston wash and EGT (1300-1350 9" from piston).
Is this plugs, ignition problem, or fuel delvery ??? if ignition what could it be and how can I trouble shoot??
