crimsonride
- Sep 29, 2005
I'm working on long tracking (to 144), lifting, and lightening an exciter right now. One thing I'm doing is dropping down to seven tooth drivers off a pz to fit a 2" track, if it still won't fit I'll be moving the heat exchangers outboard. The guage pod is going to be removed and mini guages mounted on the chasis and the bars raised. I'm simply cutting and welding an insert into the rails to gain my extension. Was thinking of moving the whole assembly back a little too. As far as skis, i've always like the arctic cat parabolics so that's what I've put on. They've recieved a bad rap in the magazines but I still like them.
arlan_jacob
- Mar 15, 2006
crimsonride said:I'm working on long tracking (to 144), lifting, and lightening an exciter right now. One thing I'm doing is dropping down to seven tooth drivers off a pz to fit a 2" track, if it still won't fit I'll be moving the heat exchangers outboard. The guage pod is going to be removed and mini guages mounted on the chasis and the bars raised. I'm simply cutting and welding an insert into the rails to gain my extension. Was thinking of moving the whole assembly back a little too. As far as skis, i've always like the arctic cat parabolics so that's what I've put on. They've recieved a bad rap in the magazines but I still like them.
I did this to my exciter you have to remove the heat exchanges from the tunnel and add running bord coolers off a polaris. I also had to run coolent hoses through the seat to the rear heat exchange works great but i only have the 136 with 2". http://www.snowmobilefanatics.com/forum/topic.asp?TOPIC_ID=10885
