YAMMIEGOD3:16
WHEN YOUR DONE WITH YOUR HC SET-UP. SEE IF THIS IS FASTER IN 500 F.T. !!
MAXXIMUM WHITE SRX SPRING (srxwht is part # in their catalog)
note: you may want to add one
engagement shim
8BU-00 95-96 V MAX 4 800 WEIGHTS. RUN 13.3 RIVETS IN BOTH HOLES.
51-43 HELIX @ 3-6 OR 90 DEGREE.
RUN 2000-2001 SXr 700 GREEN CODE SECONDARY SPRING!!
THIS SET-UP ROCKS FOR DRAG RACING. YOU WILL RUN WITH F-7,s WITH THIS SETUP. !! 3:16
engagement shim
should add that to the clutching in the Tech area off the main side bar...great info
O's srx
VIP Lifetime Member
yammiegod, see my reply in my original post.
Thanx.
Thanx.
