YAMMIEGOD3:16
WHEN YOUR DONE WITH YOUR HC SET-UP. SEE IF THIS IS FASTER IN 500 F.T. !!
MAXXIMUM WHITE SRX SPRING (srxwht is part # in their catalog)
note: you may want to add one
engagement shim
8BU-00 95-96 V MAX 4 800 WEIGHTS. RUN 13.3 RIVETS IN BOTH HOLES.
51-43 HELIX @ 3-6 OR 90 DEGREE.
RUN 2000-2001 SXr 700 GREEN CODE SECONDARY SPRING!!
THIS SET-UP ROCKS FOR DRAG RACING. YOU WILL RUN WITH F-7,s WITH THIS SETUP. !! 3:16
engagement shim
should add that to the clutching in the Tech area off the main side bar...great info
yammiegod, see my reply in my original post.
Thanx.
Thanx.
