hereismylife
I have the alternate reverse on the machine and tring to fill the fluid
I have a reading at the fill plug that says oil 200 cm³
I found out that this means 200 cm³ = cubic centimeter
do this mean it would be just 200 mm of oil than?
thanks joe
thanks joe
terret725
its not mm that woulf be milimeter and thats smaller then a cm but it would be 200mLs which i imagin u ment
terret725
http://convert.french-property.co.uk/index.htm
200 cm3 is .2 liters or 200ml
hereismylife
thanks for your help
now I can get this done...
later joe
later joe
FuzzButt
200 cubic centimeter = 6.76 ounce [US, liquid]
See www.onlineconversion.com there are quick formulas there that are easy to use.
200cm3 is that same as 2000 mm3
hereismylife
thanks joe
