grizzwald
Just wondering if anybody else has had this problem before, the dcs light will come on if you are just cruising at say 55 to 60 MPH and it is at about 7,000 to 7,500 RPM? It will come on, if let off the throttle and go again it will stay out for a bit, but then it will come back on in a little bit, let off and it goes away, it is a cycle!!! I have checked all the plugs, they are picture perfect, but that light just irritates the h--- out of me! I think I have a solution, but wanted to check around and see if anybody else has had this same problem, thank you! I forgot to say that this is a 2004 ViperS.
