I just got back from michigan this week. This was the first time I have been riding this winter. I just put a new 1'' Hacksaw on my '00 srx this year. When I am going through slower areas at 20 to 30 mph Ihave a strange howling vibration by my feet. Could this be from the slightly larger lug track? My shocks are shot and need to be rebuilt, could this be a problem? When I put the new track in I put a new bearing in on the clutch side of the drive shaft and the other one seemed to be fine. Does any body have any ideas?
Millinocket Rocket
make sure your track isn't rubbing your front heat exchangers. most likely it is if you haven't clipped it where the windows are.
woolyviper
was the track rubbing on built up ice and snow in the tunnel - this happened to me this weekend on my viper.
I have clipped the lugs already and there was no ice rubing an the track as far as I could see. The thing runs great, I just don't understand why I have this problem. It sounds like I am going over a steel decked bridge if you have ever heard that before.
yamaholic22
I had this same problem two weekends ago up in bruce crossing. Couldn't find the problem, thought one of my marginal snow wheels was making the vibration and noise because one has a bad bearing. Kept going. Got back to the hotel after 100 mile ride back and found that the lower center shock mount (cross shaft between the rails), between the bump stops for the w-arm on the rails, was broken. It snapped both bolts and the force of the center spring was pushing it against the rail and track, and it did some damage to my new hacksaw track. Nothing too bad, but it would've been if i would've kept going. Definately get in there and check everything out carefully.
Change your belt, and see if it stops. Maxdlx
monkey man
- Oct 27, 2005
check speedo side drive shaft bearing most last if 2000 miles due to dirt and crud also check bearings in chain case
WATCHMAKER
I once had a loud howl that was caused by a couple dry bearings in the skid. Replaced them and it went away.
Haulic, we ate in BC fri night at the motel bar resturaunt place. Great burgers. Maxdlx
I noticed the same thing at 50-55. If I'am above or below the sound is gone. The sled has 2345 miles all original parts: belt, shocks. I did not check if anything is broken. Runs great, its just the hum sound in that area?
help..........
help..........
yamaholic22
maxdlx said:Haulic, we ate in BC fri night at the motel bar resturaunt place. Great burgers. Maxdlx
Did you meet Pat, the owner? Real nice people there.
Pat the lady who owns the place, and her daughter who waitress, and son who cooks. really nice people. Really nice place, wish i could remember the name. Maxdlx
Everything on my skid frame looks good. I have to take it out anyway to get the shocks rebuilt so I will look into it further. I do believe my cluthes are out of alinement one way or another because I put a new yamaha belt on and it squeled, but I can't imagine that would cause a howl.
How do I check the bearings on the jackshaft? What other things should I look for?
yamaholic22
belt squeeling after you put a new one is most likely just because its wider than the old one so it sits up higher in the secondary, effectively making it tighter. Need to readjust the deflection with a new belt.
