Viper_Jim
Hey guys, just bought a brand new 04 SX Viper, approx 1700 kms on it so far this year.....I've been told that I should be able to get at least 180km/h out of it on hard packed snow....I've ripped my sled up a hard packed lake a few times now and the most mine will do is 140....does anybody have any suggestions as to what might be the problem here?????
Theres definitely something wrong here because a buddy of mine was on a 600 grand touring and he was getting 145 out of that.......
n2oiroc
180= 111 mph. not likely. at the most without reverse expect 106-107 and with reverse 104-105. most guys get good top speed #'s running on glare ice with a light dusting of powder. i would start by putting a new belt on. what are the rpm's? stock? is it a viper s?
Viper_Jim
The belt is in perfect condition....not 100 percent sure on the rpms and I have a stock viper er with the reverse and electric start taken off....(dealer did this to drop the price of the sled)
n2oiroc
start by checking the rpm's and make sure the belt is the proper width and sitting slightly above the top of the secondary, .5mm i believe. also check all the little stuff like track tension. if its too tight (dealers set it too tight!) you can lose an easy 10 mph!
woolyviper
I would say clean the powervalves and see what that brings - my viper will do 104-110 MPH depending on temp and what you are running on - 110mph being seen on long straits that are somewhat packed and temps near 0 degrees f.
n2oiroc
good call on the valves. make sure they are clean and synced!rx1orgohome said:I'm getting almost 180-185 km's on hard pack railbed. I'm 511 275 lbs. My 03 vip is plain no mods or elec/rev with 13,476 km's on it. I run syn oil and clean my exh. valves every 2000 km's clean and inspect clutches every 4000 km's. I don't let it idle long or let it worm up much, however I don't drive it hard the first 10 min after I start it, so everything worms up and loosen up and is lubed up. Seems to do alrite by me, pull's hard. Great machine. Switch to Ipond syn oil, clean your exh.vales and drive her. Try swiching your digital dash to miles and try your top end again, post back.
dlange
I pull about 104-105 with my 02 er.
dmaxx
On the speedo, we see 110-120 mph on stock and clutched Vipers on hardpack. Check your rpms, you want to run 8400-8600. Check to see that it holds steady rpm from shift out. Check your springs, measure the free length, and check your belt also.
JeepTherapy
I ride an 04 viper. when my power valves didn't work it was topping about 90, with the power valves working I have seen 113 tops... on the speedo... my power valve cables were miss routed
viperken
Check your valves, get them adjusted. Keep your track loose (just enough so it doesn't rachet on you).
Check to see if you are getting good fuel mileage! trust me my viper was slow when I got it, it was the fuel mixture screw was set too rich from the factory, it made the difference!
Try these things and I'm sure you should gain speed.
This weekend we were two on the sled with saddle bags on a lake and I got 161 km/h on the speedo. I know alone I will get between 175 and 180 km/h
Good luck
Good luck
Viper_Jim
About the fuel milage.....I'm getting OK milage, but no near as good as other viper owners have told me they were getting. I'm actually only getting roughly 150-160 kms per tank....I ride fairly hard but most of the time on a groomed trail. This is only my first year with this sled but I know it isn't performing up to par so far, tanks for all the tips guys
Viper_Jim
Just thought I'd add....I've been running Yamalube and a general 2-stroke oil in my sled this year....what are most of you guys burning in your sleds??
viperken
I run Shell Advanced (not the synthetic). Your fuel mileage seems to be poor. I had the same problem with mine. Are your plugs black? You can easily down jet a viper to 153.8 on the main jet and adjust your fuel mixture screw to 1 7/8 turns. Once I did that my viper was getting much better fuel mileage and was much faster.
