SNOWRULES
My 98 srx 700 has an intermitent fast idle sometimes when I come to a stop the revs will stay at about 3800-3900 if i blip the throttle sometimes it'll come back down to normal but not always. if i just leave it it normally drops on it's own after about 10 - 15 seconds. anyideas what this may be? i do have the pilots jetted down one size but never had this happen last winter just started this winter.
SRX7
Whats the air screws set at? Stock is 1 1/8 turns out. Maybe go a little more out to richen them up?
Oh by the way do you want to meet us in Orleans to head to Yami Fest on the sunday?
yamaholic22
Yamaha's dont have air screws, the screws on the bottom of the carbs are fuel screws. Open them up an 1/8 turn more and your problem will disappear. Also make sure your throttle cable isn't too tight.
SNOWRULES
throttle cable is plenty loose and i had the fuel screws way out already and it had the same problem. and srx7 i am away this weekend so can't join you sorry.
yamaholic22
what do you have your idle set at? Did someone change the pilot jets in it?
SNOWRULES
the idle is set at 1800 and it stays there bang on when the revs drop and i did drop the pilots one size but didn't have the high idle problem till this year and the pilots were dropped last year.
taped throttle
keep an eye on ambient temperature. when temps change you should notice the problem change. changes in altitude can also cause the problem.
ccrider
My sled does this also though only at about 2500 rpm.....my buddy's F7 also does this all the time also. This is a general artifact of some carbed sleds. Personally, I do not worry about it because it comes down fairly quickly or with a quick blip of the throttle and it performs well.
SNOWRULES
this problem is worse when the temperature is colder so it seems it's cause the low end is too lean so my next step is to try changing my pilots back to stock but it runs really well with the pilots that are in it now and i'd hate to change them if that isn't the problem.
ccrider
Don't change it then....if it runs good, then rock on!
Just give it a shot of throttle when you want it to simmer down.
SRXtrafast
You may want to go to 1/2 choke quickly and then back off again. This will bring your R's down to normal idle. The problem is that your sled is running too lean but I don't know what causes it.
bluelightning
mine was doing that.....ended up melting the mag side piston due to bad crank seal.....
SNOWRULES
ya i don't think it's a bad crank seal cause i've been riding it pretty hard doing some really long top speed runs and have had no problems if it was a bad crank seal i'm sure i would have blown the motor by now. guess i'll just leave it and live with it.
SRX7
snow mine does it also, i think its the nature of the beast.Actually the guys I ride with A/C, Skidoo, and older Pol all have that issue.The skidoo guy always blips the choke cause if he does not and he shuts it down at high rpm it lets out a big bang just before it turns off.
SNOWRULES
cool guess i'll just live with it.
taped throttle
spray some starter fluid around the crank seals, if idle races you have a bad seal.
otherwise, it's a fuel screw adjustment. you're lean. if you don't mind it, you can run it the way it is. if you fix it, you may find that it will load up when it temps rise.
can consider remote fuel screw adjusters but very pricey new or check out tech sec. on making your own.
the nature of carbs.
BenderSRX
SnowRules i live in Ottawa also and mine just started doing this a couple of weeks ago and i beleive it is the weather, the last week and a half has been really cold, i bet if you try it today it won't do it.
SNOWRULES
ya i find it's really not as bad on days like today
BenderSRX
Snowrules do you ever ride near Constance bay area
KING OF THE LAKE
Very Common With Flatslides-tolerance Opens Up A Bit Due To Normal Wear Between Body Of Carb And Slide Itself Which Causes Intermitant Lean Condition. If Fuel Screws Dont Fix Go Back To Stock Pilot Jets Or Live With It And Quick 1/2 Activate Choke To Bring Idle Down.
