DoktorC
. The NBSSR TRAIL improved stock 700 record is 119.9 held by GMCSRX.
Are you sure that's right? I know Larry Simon's sx used to run 122-124 in trail improved and my brother's 99 SRX ran over 120 as a stock sled. Maybe they've changed the classes since then..it was a few years ago now.
Congradulations either way!! Good to see blue still putting up the numbers!
deekersrx700
I'm not sure, Claude told me 119.9 in Trail Improved. Wow if its 124 I've got alot of work to do. lol
It's all fun either way, great way to meet awesome people.
Deek
Deek
Fastsx
Actually I ran 123.2 but back then we there was no Trail class and we had speed tracks. 120 with a stock track is very respectable...Fastsx
valin
Any idea what the record is for 800 improved trail?
valin
We should talk to Claude and see if he will build a webpage to post the records for each class.
deekersrx700
Good idea ryan, apparently radarruns.com and NBSSR are getting together on a new website, thats what I heard anyhow.
valin
Nice. Hopefully this upcoming weekend will be a go.
Triple X
Congratulations! to all you SRX test pilots.
can you tell me what mods can be done to run in the Trail Improved Stock 700.
thanx.
thanx.
deekersrx700
Triple X
must use a trail track, can't be tied down, you can see all the rules on NBSSRs website.
Deek
Deek
Triple X
Deek.
I just visited their website and got all the infro i needed,Thanx.
I'm from Peterborough and on Chemung Lake my best pass was 121.4(2000 ft.) and on Rice Lake 112 (1000 ft.)
X (Dave)
X (Dave)
valin
Trail Improved Stock:
Track and Suspension
Speed tracks are NOT allowed in Improved, minimum of 0.500 lug.
OEM front suspension must be used,addition or removal of wheels permitted.
Idler wheel size and material change permitted.
Enviromentally friendly lube systems NOT allowed.
OEM ski's or aftermarket ski's must be a minimum of 40 inches.
Rear suspension can be NON OEM. Must be a trail suspension.
Suspension must retain 2 inches of front and rear travel.
I didn't realize this, but it looks as though the sled can be tied down, providing you maintain the minimum of 2" of suspension travel. It only states in the Trail Stock Classes this:
Trail Stock Class
Speed tracks are NOT allowed in stock classes. Minimum 0.500 inch lug height.
OEM suspension must be used,addition or removal of wheels permitted.
Must retain OEM drive sprockets.
No lowering of the machine is allowed.Suspension must retain 2 inches of front and rear travel. The only way of lowering a sled is by using the provided factory adjustments. No straps, chains or wires permitted.
Carbide tiped trail studs only.
Trail Stock Class
valin
Looks like I've got some lowering to do
deekersrx700
Hey ryan, thats what it looks like, I didn't realize that it didn't say you couldn't be tied down.
Deek
Deek
deekersrx700
Ryan, I emailed Claude and he said that we can't be tied down.
Derek
Derek
valin
Argh.
How does it sound for this upcoming weekend? Is Claude still planning on holding it? Sounds like it's going to be cold all week.
pretty simple to lower a srx without tying it down, simply place a piece of ductape up around the frt spring colars, lower frt by reducing the spring tension. For the rear, install larger or even double the rear transfer rod bottom spacers, then suck up front limiter straps.
valin
Ya, she's fairly low now.
deekersrx700
deekersrx700
Lets pray that mother nature cooperates and we can get the last one in boys!!
