97 SX600 drivers
kysledneck
Georgetown KY
Hello! I want to upgrade this summer again, Could some one tell me what drivers would be the BEST for this sled? 9" 8" I see it has just 2 under there can I get 4 of them on! fully clipped 1" Camo track. also want to change any bearings down there& the jack shaft one also. Any info on this would realy help me! Thank you! Dan
Cut off your outer drivers (wheels) and replace them with srx outer drivers. I say cut them off, as you would only need to press the new outers on from each side, rather than press them all off and start with a clean shaft.
So the middle ones are fine no upgraded drivers worth the trouble? Thank you!
outter drivers will probably be fine in place of those idlers. If you really wanted to eliminate ratcheting with a very loose track you could always go with extroverts.
