cougar1985
will the extra 12 susp. out of a 1997 polaris xlt fit and work for the 1994 vmax 600 with out massive mods?
FuzzButt
Don't know. My Dad has one lying around maybe stuffing it in his Viper will quiet down the "Harsh Ride" comments.
If you need a measurement sled my family has a couple Polaris's with the Extra 12 and one with the Extra 10. The only thing I can say is the 12 is an awfully heavy skid. There is a lot of steel in it. Set up correctly though it is a comfy ride for a trail sled.
yamaholic22
Xtra-12 also is horrible for weight transfer. If those things dont bother you, go ahead and try it. Let us know how it works out.
FuzzButt
Ya even on the 500 classic you can nearly make it do a rocking motion front to back by getting on/off the throttle.
BlueIronRanger
- Nov 26, 2003
I know the Xtra-10 wasn't a "coupled" design, but Is the Xtra-12 "coupled"? Long travel suspension without "coupling" isn't that great.
FuzzButt
They are both coupled. The x10 is a rising rate 2way coupled and the x12 is a falling rate 2way coupled. There is a difference between the 2. Big difference. My Brothers '96 700 has the x10. The other 2 sleds have the x12.
I like the pro-action. My XTC has a great ride and does everything predictably. Fast, slow, corners, hills. It's a barrel of fun.
I'd try to stuff the proaction into the '94. If you have a '96 available to take a look at it might help. or the M10. Your limited on the Pogo's really. I remember how badly they took bumps on my '88 Exciter.
cougar1985
ok thanks guys it was just a thought. i will keep looking .actually trails were great this year so a long suspension was not really necessary. maybe a big bore kit is in the offing over the summer? i really like this sled and really hate to part with the cost of a new nytro or apex.a friend of mine is going to buy the new phazer so it will be interesting to see it and how it runs..
sandmanmike1
I just seen a viper skid on here for $275 If you use a polaris skid spend the extra for a edge suspension. I put a 2000 venture pro-action skid in my 94 vmax 600 ST longtrack and it took about 7 or 8 hours. Just make sure you have mounting locations from donor sled. If you need help feel free to ask.
cougar1985
thanks will do. will see over the summer which direction i will go,long travel or big bore kit etc.
