2001 700 VMax piston questions
chall
Ottawa, On, Canada
Hi all,
Can someone tell me what the compression should be on this sled across the 3 cylinders?
My sled smokes a lot more now than when I first bought it when I first start it. Blue in color. After it warms up, it doesn't smoke as much but color turns to black.
Also, at 13,000 km (8100 miles), should I change piston and rings, or is it OK to just change rings?
Any thoughts?
Thanks,
Chris
chall said:
Hi all,
Any thoughts?
Thanks,
Chris
At 8100 i would definitely do the pistons too
Compression should be within 10% of each other.
8100 miles if you have it apart then you might as well get the whole enchalata. Pistons, rings, pins, clips, a light hone to staighten up the cylinders.
I would not worry about the smoke. Better to smoke than not at all. How's your oil useage?
I am using up oil at a ratio of 50:1 which is on the money, but my gas milage has gone to the pits. Where I used to use $20.00 in gas, I am now using $25.00.
Cheers,
Chris
Cheers,
Chris
How many mpg can ya get from a tank???
chall said:
After 100 miles, I had better find a gas station quick. I am past the E and swetting.
Really...wow,,i can do better than that on my old 95 VM with a 10 gal.
tank..time to fresh'n that baby up for shure...
