Good night for racing here in NY, when we pulled in was 62deg and sunny… At the end of the night the track got slippery and dew started to settle in… Temp was 51deg when we pulled out at 10:30pm. Got out to NYIRP last night for the first time (test-n-tune) at the track, again I can not say enough about this track and how great they are, thanks again to the owner Bob… Running sled at 14.5lbs of boost... for now..
Here are the numbers with some notes… There was only 2-big cars, a couple of mod cars that were putting down the rubber, all the rest were imports, bikes, one other sled (he blew up), but did get a chance to see the new 06-Proline skid (nice…), and street cars.
Run1: Pulled hard to the left had to let off at the 500ft mark; made adjustments for the next run
1.49 60’ - 6.38 1/8 @106.05 - 10.02 ¼ @ 134.54
Run 2: Still pulled to the left, but not as bad had to let off at the 660ft mark, then got back into it; made some more adjustments for next run
1.54 60’ - 6.00 1/8 @ 110.9 - 9.612 ¼ @ 135.72
Run 3: Finally a solid run…
1.49 60’ - 5.97 1/8 @ 110.70 - 9.55 ¼ @ 136.03
Run 4: Adjusted some secondary belt deflection on this run, and made a small adjustment in the skid
1.47 60’ - 5.95 1/8 @ 119.33 - 9.38 ¼ @ 139.72
Run 5: Took some mid weight out of the ST’s… Now we are having some fun…!!!
1.48 60’ - 5.82 1/8 @ 121.73 - 9.17 ¼ @ 141.68
Run 6: Made this run to back up the first run, but forgot to record the rpm via. VDO Tach… my bad…
1.48 60’ - 5.83 1/8 @ 121.27 - 9.16 ¼ @ 142.67
Run 7: Made this run just for fun… But, I lined up in the in the worst spot of the night in that lane, spun bad… BUT…
1.50 60’ - 5.85 1/8 @ 123.49 - 9.13 ¼ @ 144.67
