viper help ( Drivers/chain Case needs to come off)
Did you remove the parking brake? If so it should just slide off there. If not then the rotor has to come too and they can be a real pain to get moving. Lots of lube and a BFH will usually do the trick.
No BFH!!!!!
That WILL cost $$$$$
The chaincase does need to come off to get the track out . Remove the speed sensor , remove the caliper , remove the p brake , remove the secondary . You should be able to slide the case off . If not try sliding it back on then try again . Once off you wil need to remove the 2 torx screws on the inside of the left axel bearing . Now remove the 3 nuts holding the bearing to the tunnel , remove the bearing . Now you can work the axel out . It takes a bit of fidiling but it will come out . To install reverse procedure . Be patient take your time and everything should be fine . :WayCool: ;)!
