sniperviper
Thinking of adding rail extensions on my viper and wondering if any of you have tryed "144 tip up rails" from Tracksusa and what you think of them?
n2oiroc
i have rode a switchback with those rails and really like them. it cornered as good as my 136" viper. i think its the best way to go!
sniperviper
Think I'l do that
Thank you for answer!
Thank you for answer!yamaholic22
those really caught my eye too, would love to give them a try.
sniperviper
sxviper32
could one take the rails they have and make them "tip up"? just machine the back corner, would that work? thanks!!!
sniperviper
Dont know exatly what you meen but the tip up rails extensions from tracksusa are machined in an angle, like polaris rmk and switchback.
n2oiroc
its the back 10" that tip up at a 2* angle i believe. you cant machine that into old rails. there wouldnt be anything left to hold the hifax on with.sxviper32 said:could one take the rails they have and make them "tip up"? just machine the back corner, would that work? thanks!!!
sxviper32
oh, ok. i thought it was something else, nvm then.thanks tho!!!
2stroken
just bend the rail
If you want tip ups that badly, just bend the rail
n2oiroc
well you could cut the back off the rails, grind a little angle to them, weld them on and grind away. but im not sure how well extruded aluminum welds. i know what your thinking and i prefer the look of solid rails too. but unfortunatly unless you swap a polaris skid in, extensions seem to be the only option. if you want to make sure the extensions match the rails get them powdercoated after they are pressed together like i did!
