SNOWRULES
have a 2000 sxr700 that i'm about to put PSI tripple pipes on and a heelclicker primary kit. right now i'm running it with 14.5 mm rollers as per turks tuning tips on the tech pages. just want to know if i can use the same rollers when i put my heelclicker kit on or if i should go back to the stock rollers. i just heard that the heel kits can blow up the 14.5 mm rollers. anybody have any input?
you simply can not hook up with 14.5 rollers, it will explode with power down low and I dont care what track, what amount of studs, you wont be able to keep it from trenching and spinning, and then overshifting. It also will not let you run any weight in the weights, which pretty much makes them useless.
SNOWRULES
ok so the stock rollers are my best bet. any tips on jetting and clutching with PSI pipes with heelclickers? i currently have stock .92 track, 144 studs, maxx performance transfer rods, one layer removed from head, stock secondary clutch, reed spacers and currently jetted one size down on mains, one size down on pilots and a half needle clip leaner. jetting i can do just gonna go 2 or 3 sizes up on mains see where i'm at and adjust from there. mostly concerned about the clutch kit and where to start with that any tips would be great mr. viper. thanks.
SNOWRULES
sorry forgot to add the pipes are the stockbasters and spin at 8800-9100 rpm
SNOWRULES
anyone else have any input?
yamaholic22
15.6's or 16's for the rollers.
SNOWRULES
15.6 are the stock rollers that i have, that i'm going to put back on when i install the heel kit.
I would try 15.6 rollers, red spring, 4-5 grams in the heel, 4 grams center hole and empty tip
SNOWRULES
thanks mr.viper i'll try that for starters then tune from there just wanted a starting point to get me going. thanks again
