deekersrx700
Just like it says. thanks
**sj**
Life Member
I believe it's 8500
8600 and up
deekersrx700
How many degrees would it be retarded at say 8800 rpms?
ALOT!!!!!!!!!!!!!!!!! would not be any good, would not rev and run, will stutter
deekersrx700
Ok thanks just learning!
aSRX600guy
my 98 was different. there was no spark cutout, but made no power.
while over reving (about 1000 rpm). it would actualy go faster at half thottle than wide open
yamaholic22
nobody said anything about a spark cutout, just heavily retarded timing, which is the case on all of the srxs after 8600.
aSRX600guy
yamaholic22 => nobody said anything about a spark cutout, just heavily retarded timing, which is the case on all of the srxs after 8600.
this is were I got the cutout idea from.
mrviper700 said:ALOT!!!!!!!!!!!!!!!!! would not be any good, would not rev and run, will stutter
yamaholic22
oh i see where you got that idea. However, he just meant that the timing is so heavily retarded that it will not rev any more because it doesn't have the power to do so, so it will be putting more load on the engine than it can pull, and it will stutter.
