What are the best ways to reduce friction around the track rotation? Oversize idler wheels, marginal snow kit, Hiper fax (although I won't spend that much on hi fax), anything else? Looking for optimization of top speed and gas miliage. Thanks
aSRX600guy said:the narginal snow kits actualy increase drag to some extent. keep the stock wheels on the skid. a bigger wheels at the major bends (rear axle, top, drives; last 2 may be tougher to do) will make a difference. you want to minimize how much the track has to flex.
for a sliprier hyfax, just drill it full of holes.
a low profile track will help.
minimal or worn carbides.
a narrower track would do some good too.
dont neglect the gear train, synthetic lube might be the best, but I haven't look into it. just like big wheels, use big sprockets were you have a choice. check all bearings everywere. you may want to look into a SRX or shorter. suspension if your real serious. if you've got triple pipes on your viper, a srx cdi will help fuel economy more than anything else I've been told.
kinger said:PS Its really ok to use ATF in the chaincase?
mrviper700 said:7.5"oversize rear wheels, 5.350"skid wheels and the marginal wheels at front curve bar none, this is a major decrease in parasatic drag.
