srx powered viper
snow3
Central Pa
I was wondering if there is a way to use the stock guages on the viper with a 98 srx engine in it. All of the electronics are out of the srx..
the guage uses all the same inputs. there is one input for the temp sending unit, you will have to wire a resistor in line to ground for the temp light. if you dont wire it up this way it will flash an open signal and you wont be able to use any other warning systems
the srx uses a temp signal to the box ,
you will just need to add the wires for the pickup and power them.
get the two different wire diagrams and trace it out, the wires are all there
