WHAT
that's a Phazer - you asked me before about mine - I never noticed. I looked at your picture and had no idea. It looks fantastic – what imagination.
Aren’t you embarrassed to show that when all the talk is big stuff.
Mine is stock except the engine is to factory dimensions. The only thing off was the cylinder height – not much. We have the same skis –Kevin sponsored us 99/00. Our SX500R is on the cover of his 2000 brochure.
We used the big family sled rear transfers rods as the washer stops were farther apart. If we do anything, I’d like to lower the chain case so we can lower the front of the skid to get some weight off the skis.
The track is stock – rolls nice, the clutch has seen extensive work – it snaps to max RPM and sits there in any conditions if it’s pinned. We have it soft mid range and it up shifts slightly pulling the rpm down for better mileage. We had a box full of Advant-Edge helixes to work with – I’d say they are about like about 100% better than stock.
The carb has a good range of jets and its pretty well stock except for the low speed circuit.
Certainly – it does not hold a candle to the looks of yours. I may be swayed by the new Phazer. Maybe???
