SRXtrafast
What's your opinion on this susp. for 00srx700?
aSRX600guy
love my expert equiped SRX. had to crank the front preload, the bumper was shearing off moguls
ViperTom
I put one on a Viper I had a couple of years ago and loved it. Rode great in the bumps and weight transfer is unbelievable. I tried my hardest to beak the thing and it just begged for more!!!!
Tom
Tom
Struggled with setup on my RX-1 at 1st, but once it was dialed in it was great.
Gotta love that transfer!!
TopGunnSrx
I have one in my 01 srx and i loved it. Im taking it out and going to try it in the SX we have, I think that sled would be better suited for it and easier to pound then the srx.
The srx is just to nice for me to beat to hell....
SRXtrafast
aSRX600guy said:love my expert equiped SRX. had to crank the front preload, the bumper was shearing off moguls
If that's the case , I would switch the top mounting brackets for the front ohlins from side to side. Someone mentioned that on here once and w/ a little grinding they will switch easily and it should raise the front about an inch. I'm not looking to run snow cross just a better ride when you hit rough trails and of course good transfer for lakes. Still in thought though, need more feedback
Expert X
The Expert skid was probably the best money I ever spent on my SRX, and I,ve spent alot. Its easy to dial down the transfer to rail around the corners, but its SO much fun to turn it to full transfer and ride around with your skis in the air. It may not have quite the ride of the M-10, but the ride is 10 times better than the stock proaction. I'd say go for it, you won't be dissappointed.
aSRX600guy
if you've got ohlins, there are extentions you can get
shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
You could also buy different shock mounts to raise the front even more, or just flip them around.
TopGunnSrx
SRXtrafast
TimeBomb
go for the expert, the m10 blows
custom sled shop
Xpet X!!!
far as skids goes??? This is the best!! just my 2 cents!!
Oh! and there on sale untill sept 1st!!
www.customsleds.ca
stock sucks!!
www.customsleds.ca
stock sucks!!
