electric start
Hi Eric..
sent you an email ....
I have a electric start 73 EW433 engine , out of frame ,ran ok
when I tried to may a EW643 out of it ,,,noticed bolt pattern was
incorrect for hydraulic unit too late ,,,so I left it apart ...
Monty has added electric start to machines that came without
but did you want to stuff the SRX in for fun or to use as a cart ??
It would be a heck of a ride !! old ezgo carts used a detuned
Kohler 295ax twin with a reversible belt genator and a slotted stator
to bring the points over centre for reverse ...neat idea ,,,but I expect
your cart has a reverse gear ....Don't get any ideas about the PR either .
Probably would be difficult to mount unit and the cart would need
additional brakes as well . the unit brake is too small to hold a machine
that rolls easy on wheels .
ps ..this engine could probably use points and carb work as well but
was working OK a 1 1/2 year ago
See you in July ....RON
