checking the 2 small wires on the coils, this is the hot and the ground, with a digital meter set on the 20k ohm scale(upside down horseshoe) with the 2 wires you should read "0" resistance.
with the spark plug cap removed, you should read 6.85-6.98 ohms thru the end of spark plug wire to the small wire, I checked all 3 and they all were in this range.
