pro116 Lifetime VIP Member Joined May 7, 2003 Messages 2,764 Age 44 Location Appleton,WI Jul 22, 2006 #1 The srx left trailing arm part # is 8DF2382E-00-00 and the xtc trailing arm # is 8CR-2382E-03-00 does anyone know the difference?I have some painted srx ones I want to put on a xtc.Thank's
mrviper700 VIP Lifetime Member Joined Jan 14, 2004 Messages 7,363 Age 54 Location Ohio Jul 22, 2006 #2 the 8df arms have a "v" mark, they are 23.5 degrees caster,3 degrees radius rod angle,10 degrees shock angle. the 8cr has "R" mark, 25.5 degrees caster, 3 degrres radius rod angle on brackets and 10 degrees on shock brackets. you can swap both of them as a pair, a little more castor will just make it steer a little easier.
