Trailing arm ?
pro116
Lifetime VIP Member
Appleton,WI
The srx left trailing arm part # is 8DF2382E-00-00 and the xtc trailing arm # is 8CR-2382E-03-00 does anyone know the difference?I have some painted srx ones I want to put on a xtc.Thank's
the 8df arms have a "v" mark, they are 23.5 degrees caster,3 degrees radius rod angle,10 degrees shock angle.
the 8cr has "R" mark, 25.5 degrees caster, 3 degrres radius rod angle on brackets and 10 degrees on shock brackets.
you can swap both of them as a pair, a little more castor will just make it steer a little easier.
