2002 viper
- Aug 7, 2006
I have a 2002 viper and we took the air box apart to take care of the fuel pump problem and ever since we did that the sled over heats now( in winter) and it hesitates in mid range. What can be doing this?
PowerValve-700
- Make sure the carb vent line is plugged into the air-box.
- Make sure all 3 boots are correctly fitted over the back of the carbs and all clamps are tight. (Most likely the problem, take the top of the air-box off and remove the shelf so you can have a good look at the back of the carbs from inside the air-box.
2002 viper
- Aug 7, 2006
I will check that out now.PowerValve-700 said:- Make sure the carb vent line is plugged into the air-box.
2002 viper
- Aug 7, 2006
What about the over heating problem?
PowerValve-700
I'm not sure if anything you did caused it to overheat or not but you should add a rear heat exchanger if you havn't already.
2002 viper
- Aug 7, 2006
The problem started right after we did that. I think we drained the coolent system when doing so maybe there is air in the system when we filled it?PowerValve-700 said:I'm not sure if anything you did caused it to overheat or not but you should add a rear heat exchanger if you havn't already.
PowerValve-700
Possibly, if the cooling system was opened it needs to be re-bled.
http://www.zenitram-inc.com/Manuals/bleeding1.jpg
http://www.zenitram-inc.com/Manuals/bleeding2.jpg
A tip, (bleed screw 2) you may have to slacken the hex bolt on the bottom of the heated carb valve and pull the valve out slightly (about 1/4") to get coolant and air bubbles to escape from the bleed screw hole.
2002 viper
- Aug 7, 2006
Thank you, you were was BIG help!PowerValve-700 said:Possibly, if the cooling system was opened it needs to be re-bled.
PowerValve-700
No prob, but that was just my suggestions, maybe someone else can chime in with their suggestions. Let us know if you get it fixed!
