What is the right adjustment for the limiter straps? I put in adjustable rods in this summer and I'll have to play with their adjustments when the season starts. But how much should I adjust my limiter straps in?I know that the more you tighten them it puts more weight to the front ski's. What is the adjustment that you guys go by as a rule of thumb?
SNOWRULES
if you like to lift the skis leave about 1-2cm of thread past the top nut on the adjuster then tune from there thats what i do. you'll love you adjustable rods though makes that sled hookup alot better i just put them on mine last year you can almost use the rods to adjust ski pressure and how hard it bites in the corners. good luck
Thanks there SnowRules.Should be a big difference.
Well I see that my limiter straps are adjusted with about 1/4 inch of threads past the adjuster nut. This is a good starting point.My adjustable rods have the nuts about 3/4 inches of space to the rod body. I don't know until I start to ride and do testing.
