limiter straps
Howden ,Manitoba,Canada
What is the right adjustment for the limiter straps? I put in adjustable rods in this summer and I'll have to play with their adjustments when the season starts. But how much should I adjust my limiter straps in?I know that the more you tighten them it puts more weight to the front ski's. What is the adjustment that you guys go by as a rule of thumb?
if you like to lift the skis leave about 1-2cm of thread past the top nut on the adjuster then tune from there thats what i do. you'll love you adjustable rods though makes that sled hookup alot better i just put them on mine last year you can almost use the rods to adjust ski pressure and how hard it bites in the corners. good luck
Well I see that my limiter straps are adjusted with about 1/4 inch of threads past the adjuster nut. This is a good starting point.My adjustable rods have the nuts about 3/4 inches of space to the rod body. I don't know until I start to ride and do testing.
